GA16DE AIR INTAKE MANIFOLD
SA240SXCRUISER
Car: 93 240SX, 94 SENTRA, 2000 MAXIMA
DOES ANYONE KNOW WHAT YEAR 300ZX THROTLE BODY WILL FIT A 94 SENTRA WITH A GA16DE AIR INTAKE MAIFOLD?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
???...loose the caps, it's considered poor netiquette
as fro the TB questione? what are you trying to do? most of the nissan tb's ahare a bolt pattern and can be interchanged, I for instance an running a KA tb on my L28ET, and the same is popular for the VG30E and VG30ET
if your looking for more power you should really look at the sr swp and the sentra section would yield better results
SA240SXCRUISER
thanks for the reply
i'm trying to get more air into the engine the ga16de has a small tb
gazu
Car: nissan sunny b13 ga16de
hi there, i have a b13 with a ga16de auto. i took part in our last drag here. i palce 1st in 17 sec i ran my best time 17.5. i was thinking about a bigger tb 2. any help???? i check a site some time back they said that r.c engineering has d best tb for d ga16 de. they said it was dyno proven. i live in grenada west indies.
gazu
can the sr20 tc work on d ga16 de?
evildky
06 Nissan 350Z GT
most TB's are interchangable, the tps mounts might need to be modified but in gereral they bolt spacing is the same
SA240SXCRUISER
i have an upper air intake mani looking for a lower one as well, i'm going to port them both out, and run a 300zx tb with its air induct as well,going to put headers,strait pipe cat,and cat back too,i going to run the air intake stock at first then change to a 300z set up after. will keep posted should have pics as well.
evildky
06 Nissan 350Z GT
I really doubt the Z TB will be an improvement, I actually think it'll be a step backwards, try finding one form a 240SX, they are larger
SA240SXCRUISER
the z tb is larger than the ga16de tb and the 240sx tb will not fit.
BeyondBiscuits2
Car: 1990 Nissan Sentra XE B12 w/h 1999 GA16DE & T25 turbo
On the 1991-1994 GA16DEs, you can use the throttle-body from the same years SR20DE engines. As for the KA24DE or VG30E tbs, I would doubt they would fit, and they would royally screw your air-to-fuel mixture.
gazu
u can used sr29 tb but u have 2 port d ga16 manifold. d bolt pattern is the same.
SA240SXCRUISER
i finally got the lower intake manifold for the ga16de. i should have it ported and converted to the 300zx tb and air induct. should have pics soon.
