pos2idons wrote:i was thinking about buying like a OEM paddle shifter from 2009 maxima and then put it on my AC..
i called the dealer and they said ima have to find a place that does after market modification and i dont know any place, so does anyone know where should i go??
There are some problems with this, well not really problems, but hurdles to get over:
1. You need the wiring schematics for the paddle shifters.
2. You need the wiring schematics for the regular shifter.
3. You need to wire them to work together unless you find some other way of putting the car in manual mode without the stock shifter.
4. You have to find a way to mount them behind the steering wheel (again is there enough room?).
5. Do the paddle shifters communicate with the ECU/Trans ECU the same way as the stock shifter? If they don't you have to rewire this or put it through a conversion box to interpret the right signals.
I'm not saying it can't be done (hell, I'm doing the turbo from scratch), it's just not going to be easy plug and play. Even a custom shop may tell you to pound sand simply because it's probably too much work and something could break and they do not want to be responsible for it.
Good luck though, if you get this done I want to see lol.
