G56 Coming up
mailhot
Has anyone done a VK56 swap into a G? I just picked up my motor and stripped the coupe. Removed the secondary firewall too. It seems to fit good. Need the adapter kit for the 6spd. Anyone have any ideas?
j-
Hey J -
There's been a VK56 put in a Z, but not a G to my knowledge...
Not sure of any "adapter kit", lemme see if anyone else knows something about this swap.
We need pics!!!
mailhot
infinititech1
umm wow lol
C-Kwik
The VK56 is a beast of a motor. It's cammed for a truck, but if you can get some kind of hi-performance bumpsticks, you should be able create a monster of a G35.
yzarcur
Car: 2004 Infinity G35 Coupe
Can you PLEASE keep us posted with some progression photos of the project?
I would also love to see a dyno post when your done.
This is going to be a race car, you better bone up on your skills.
Thank you!
zozoka1212
Car: 08 Infiniti G35x
wow that's gonna be a beast.I love it. Sure I would love to see pics in progress.
Thanks man for these pics
zozoka
BigWill
Car: Gone, but not forgotten-2004 G35 Coupe-5AT-Graphite Now-2008 Black Saphire IS 250
All I have to say is RUCRAZY??
(Sorry John, I just HAD to!)
WOW that thing is gonna be wicked!!
jlo0109
I was reading wikipedia about the VK56DE engine..which one is yours? Armanda?Titan? or QX56? They are all only pushing about 20~30 hp more than the original engine..Why would you want to do all that work for that 20~30 more hp and add up a crap load of weight onto your car? O_oSorry if I am wrong.. explain to me :]!
BigWill
That may be true... but think about how much more torque and potential hp that motor could make!
C-Kwik
jlo0109 wrote:I was reading wikipedia about the VK56DE engine..which one is yours? Armanda?Titan? or QX56? They are all only pushing about 20~30 hp more than the original engine..Why would you want to do all that work for that 20~30 more hp and add up a crap load of weight onto your car? O_oSorry if I am wrong.. explain to me :]!
Dyno charts of Titans show that they either have little drivetrain loss or are underrated by about 15-20 HP. So it may be that they are starting with a bit more than the factory ratings would suggest. However, the motor makes gobs of low to mid-range torque. The peak HP also occurs at a measly 4900 RPM. Based on factory ratings, this would mean the VK is still pushing 326 lb-ft of torque at 4900 RPM. A cam that can provide better breathing up top could easily bump up the HP by allowing the motor to operate at much higher RPMs. V8's tend to have great natural balances so it should be able to withstand some higher revving. It may be limited most by a 92 mm stroke, but that's not terribly high either (A KA24 can safely rev to just over 7000 RPM and has a 96 mm stroke). Conservatively, if you could make 300 lb-ft of torque at 6500 RPM, it would be putting out 371 HP. I suspect you can get more torque somehwere up there with this motor and rev it out more too. By comparison, the new 5.7 L Tundra motor is pushing 357 lb-ft of torque at 5600 RPM where it makes it's 381 Peak HP with only a tenth of a liter more in displacement and a slight edge with it's higher compression so it's not unrealistic. If you could make even just 325 lb-ft of torque at 7000 RPM, you'ld have yourself 433 horsies to play with.
Bear in mind here that the Titan's VK is only cranking out about 67 lb-ft of torque per Liter at it's peak. The VQ in the G, by comparison, is at about 77 lb-ft per Liter depending on the version. There is likely some room to bump up the overall torque output as well.
There is a lot of potential to play with by doing such a swap. Not to mention the roar of a huge V8 if you open the exhaust up even just a little bit.
paulp
Car: 98 s14 se, 07 g35 sedan 6mt
WOWi would love to see the finished product
yzarcur
BigWill wrote:All I have to say is RUCRAZY??
I am going to have to change my name! I'm not worthy any more.
yzarcur
There is a twin turbo vision of the QX56 put into a g by Vision ( I think ) and it has 1100hp. When you go big you have more to play with. Remember the 427 Cobra? Shelby crammed a beast of a motor into that tiny little convertible and came up with arguably the most powerful car for almost 30 years when the Viper trumped it on the 0-100-0 record it held for that long.
As you were saying the power to weight ratio is going to be huge and should make it very fun to drive straight or sideways.
mailhot
More pics,
eyekutr
How is this huge and heay V8 going to fit in a rather small car ?? Wont the weight be a huge imbalance. Youre going to need like 15 inch front rotors and huge new calipers to stop this beast, not to mention suspension needs to be tweaked big time......This is a crazy task , but very cool
G_whizz
Car: 2010 G37 Coupe Sport
You MUST keep us posted on the progress of this project!!
zozoka1212
WOOHOOOO
Thanks for the pics and please keep us updated with more pics.
Zozoka
