A static test fit of the 18x9 +35mm Superleggera with 255/40 PS2 on my G50 (all stock) would suggest that +30mm might push the wheel too far out towards the fender. Not conclusive, but even the technician said he would like to see an offset closer to 40mm.ceningolmo wrote:Using the 255/40 on an 18" wheel... provided the wheel width is anywhere between 7" and 10.5" the offset should be in the +30 & +35 depending on how close you want to get to the limits.
Using the 245/45 tire on an 18" wheel...provided the wheel width is between 7" and 10.5" the offset should be between +25 & +30.
Based on the "offset calculator", the fronts would stick out 6 mm more than mine (did), but the rears will stick out 11 mm more.VIP Q45t wrote:I just seen these rims up for sale. I was just curious if these would fit on my Q45? And would I have to roll fenders, use spacers?
The specs are 18X8.5 +23 18X9.5 +30 5X114.3
http://i37.tinypic.com/amse4z.jpg
Just wanted to reply to your concern. The answer basically boils down to "how" you would like the wheels to fit on the vehicle. From looking at the specs through my "standards"-I can make the wheels fit~No problems at all!! Well, it all depends on whether if you are willing to stretch the tire, add some negative camber and maybe do some mild rolling of the lip of the fender. I currently run a 19x9.0 +11/19x10.0 +11 on my G50, so those specs (19x8.5+30, 19x9.5+36) are mild from my mind set. Just wanted to give you some idea!VIP Q45t wrote:I tried using that tire guide thing. But I doesn't really tell me if it will fit or not. How much play do I have (from stock rims) for the aftermarket rims to fit? Whats the farthest out the rims can go and the closet it can go to the suspension?
Well I have been searching around for new rims. I came accross these. But once again I'm not sure if they will fit. 19x8.5+30, 19x9.5+36
I agree.lasoyafan wrote:dude those would fit nice, maybe a little minor modding but nothing too hard!
I think this thread (below) is the one that is supposed to be "working examples".maxnix wrote:... Isn't this thread basically for posting working examples, not general inquiries?
My examples are on a Q using Eibach lowering springs.thejapino wrote:Here's a G50 fitment thread that shows you a whole spectrum of wheel fitment, from stockish to aggressive.zerothread?id=223195
they will fit. for one, they are 18's, and the width are 8.5 and 9.5. the fronts will fit fine with no mods, the rears, itll be close... if anything, you might just have to roll the lip a little bit. but they will fit. i was running 19x9 +25, 19x10 +25, and i only had to roll the rear lip so slightly, but i rolled it flat. from 18" rims to 19" rims, you gain at most a 1/4" of clearence if the offsets were the same and if the top of the rim were to sit right flush with the fender (get what im trying to explain?)... anyways, i think they will fit fine...btw, im lowered on cut springs, front slightly rubs whenever i take the turns too fast...VIP Q45t wrote:I just seen these rims up for sale. I was just curious if these would fit on my Q45? And would I have to roll fenders, use spacers?
If that doesn't give one serious pause, not much else will.mista808 wrote:
they will fit. for one,........ anyways, i think they will fit fine...btw, im lowered on cut springs, front slightly rubs whenever i take the turns too fast...
Hey, So what size tires did you have on the 19's?mista808 wrote:they will fit. for one, they are 18's, and the width are 8.5 and 9.5. the fronts will fit fine with no mods, the rears, itll be close... if anything, you might just have to roll the lip a little bit. but they will fit. i was running 19x9 +25, 19x10 +25, and i only had to roll the rear lip so slightly, but i rolled it flat. from 18" rims to 19" rims, you gain at most a 1/4" of clearence if the offsets were the same and if the top of the rim were to sit right flush with the fender (get what im trying to explain?)... anyways, i think they will fit fine...btw, im lowered on cut springs, front slightly rubs whenever i take the turns too fast...VIP Q45t wrote:I just seen these rims up for sale. I was just curious if these would fit on my Q45? And would I have to roll fenders, use spacers?
