Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Dec 12, 2006 6:14 am
There is a trunk release solenoid that fails sometimes... do you hear it "click" but it doesn't do anything? If you remove the part and it appears to be "stuck" in the open position, that's how mine failed.
The other possibility is that the "flapper" that springs to the left to push the latch open has gotten bent. If the actuator is OK, I would bend that a little more to the left... Wes posted a pretty detailed post on this a year or so ago...
Good luck!
Heath
