G50: Trans issue - Can anyone help?
rotorimp
Car: 02 Xterra, 60 IH Metro
I am more worried about the timing--as soon as I get that set I'll set the IAC.
I thought chuggle was a word made up by GM when I saw it in a Cadillac TSB. I guess its an industry-wide made up word.
FarFetched
Car: Suzuki SV1000S.
Jesda wrote:I thought chuggle was a word made up by GM when I saw it in a Cadillac TSB. I guess its an industry-wide made up word.
Chuggle - to thrust or heave forward The best of all for GMC - got mechaing coming!
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
rotorimp wrote:.----I think Engineers should be made to work on their own products from time to time. I don't think that there is any other way unless you evacuate the ac system and put it on outside the car.
I've felt that way for decades, especially since front wheel drive showed up.
After Engineering school -2 years in dealership service, or a 2 year technical degree -before you could be hired by a major automaker.
Or is that Draconian?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think the main problem is that the systems are not designed together... it just gets PUT together!
Youll notice though, most of the routine maintenance is pretty straightforeward and not a lot of crap to remove (except for the gay oil filter)
Well, despite everything appearing to be set properly, we are still having issues.
Our "laptop Consult" is reading weird on a couple parameters, so I'm not quite sure I trust it.
Looks like I'm going to be taking it in for some diagnostic time.
carlosinseattle
Car: 94 Q45a 91 Q45 Base SOLD
maxnix wrote:Did that include 6 oz. of Lubeguard Red?
I did the Lubeguard Red. I've only drive around 40 miles since, but it still chuggles. The car is a lot better since I did the flush, but it's not perfect. I'll try the TPS soon and see if that helps. I wish the Flush and filter would have solved it.
Any other suggestions? I'm totally open, and since the car still drives great otherwise, it's worth trying anything that doesn't hurt the car.
elwesso
2007 BMW M Coupe
AZhitman wrote:Well, despite everything appearing to be set properly, we are still having issues.
Do you think they'll be able to figure it out??? My hopes arent terribly high, but if they know how to work a consult and see what the trans is actually doing that may be helpful.
Yeah, I wish I could get the self-diagnostic to work.
We triple-checked fluid level, reset IAC, set timing, idle, checked the resistor...
Still acting funky, and I'm pretty certain it's electrical and not mechanical.
Could be a harness issue I guess.
FarFetched
AZhitman wrote:Yeah, I wish I could get the self-diagnostic to work.
Have you gone through the car after eng R+R at the shop?I would be somewhat suspecious about the fact you didn't have that probllem bofore eng R+R.Looks like someting is not connected correctly.Cheers!
Problem solved.
As Dennis guessed, it was the TPS.
Swapped on a new TPS for the late 95, 96 model and all problems gone.
Yay!
