G50 Trans. cooler lines
RustyBucket
Car: '94 Infiniti Q45
What size are the transmission cooler hoses on a '94, specifically the ones that go to the external filter?
I'm planning on replacing the external filter with a magnefine when I put in my trans. cooler and I want to make sure I order the right size.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
3/4 Inch.
Get the Magnefine Performance Edition Filter because the inner cartridge is replaceable ($4 MAX), You can check the condition of the filter without destroying the case and it has metal line attachment VS plastic which puts me at more ease/=.
RustyBucket
3/4" must be the outside diameter... what's the inside diameter?
