JZX91-2JZ »
https://forums.nicoclub.com/jzx91-2jz-u119837.html
Wed Apr 07, 2010 2:22 am
So today went to start it to drive to the workshop...
Starts fine as always, idled fine left it for a minute or so.
Engage reverse, Fine! (WOOOHOOO)
Select drive...Takes about 10 seconds and engages (this has been happening prior to current issue)
Now car is driving fine in reverse drive and park and neutral there is a whirring noise from 800-1000rpm the noise does not get worse or better due to the temperature of the car but the car drives as smooth as normal.
I cant hear that same noise at revs above about 1000 the car shifts and responds as normal.
Thoughts so far?
