G50 Stalled
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
My Q45 stalled in traffic on the freeway yesterday. I have not idea why and it started right back up.
It has 30k on the transmission fluid, and 60k on the plugs. I have the plugs and the pan/filter on order I am not sure either of those would cause an outright stall.
It has 120k, and had dealer trans flushes up to 60k ,and then a BG flush a 90k according to records. The plugs where changes at 60K
I checked the injectors that all where 12.8 +/_ .2
Knock sensors one was 550k ohms the other was 448K ohms.
Cleaned the MAF
This was all tested on a cold motor
96Qowner
Car: 1996 Q45
I think your MAF is failing. Eventually, cleaning just doesn't help.
My guess is if you do nothing and just watch, you'll start seeing progressive MAF-failure symptoms - stalling on deceleration, hiccups on the highway, etc.
Should probably treat your connectors - MAF, CAS, anything else you can get to.
You've seen the recent MAF-failure posts?
Fixed MAF in spare time
silver2k2
Thats good information. I will start looking for a replacement MAF and try the repair on this one. New ones are 450.00 dang
goody90q45
Car: 1992 Infiniti Q45 (sold)
Any ECU codes? If there are none, other than 34 (KS), I'd be looking at fuel delivery, specifically the FPCU. Have you had a chance to pull the connector on the FPCU and check for scorching? I have a spare MAF if you want to borrow it and swap it in.
silver2k2
I pulled the codes and got 12 Air Flow Meter. Car has started 10 times with this fault. Looks like I need a new MAF
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
maybe. could also be the pins. i'd try cleaning up real good first--stabiliant-22 is the hot ticket for electrical contacts.
at least youre narrowing it down.
silver2k2
Thanks Jay I will give cleaning it a shot.
I know this is probably unpopular, but has anyone tried a reman one? They are around 280.00. 458.00 from Joe, or 80 for a used one. My fear is a used one may be just as bad as mine considering it has been running fine since the stall. Anyone have a broken one they would sell me cheap so I could try surgery on it?
Can a new plug be purchased to elimate this troublsome area?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Heres what I think. you can buy a bunch of used ones for the cost of one new one, certainly after 2 you'd have yourself a good one!
I would buy a couple used ones to have as spares, i have one on hand at all times.
silver2k2
I see your point. However even if I find a good one, who knows how long it will last. Q45tech says its very hard to even test them
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
silver2k2 wrote:I see your point. However even if I find a good one, who knows how long it will last. Q45tech says its very hard to even test them
Aye, there's the rub!
Check connectors, solder condition there, and treat with S22 first. Then go new.
silver2k2
Anyone have a broken maf I can practice on?
96Qowner
Car: 1996 Q45
goody94q45 wrote:I have a spare MAF if you want to borrow it and swap it in.
silver2k2
Thanks Goody already offered and he is within driving distance. I am pretty sure my MAF will continue to get worse, its just a matter of what to replace it with or to try and fix one
DrewQ45
Car: 1990 Infiniti Q45
silver2k2 wrote:It has 30k on the transmission fluid, and 60k on the plugs. I have the plugs and the pan/filter on order I am not sure either of those would cause an outright stall.
I have 120K on my current plugs. I've had the new plugs sitting for like a year now. Running like a champ. Sigh... I need to get to it though.
