Well here it is, I found a way to do it by trial and error of messing with stock components. So for anyone who is doing a transmission swap, engine swap or what ever on a G50, its possible to keep your powersteering!
First you start with the speed assist solenoid, mount it to some sort of fixture so you can unscrew the solenoid.
solenoid apart with the regulation fitting and spring.
Now the spring used to go between the regulator fitting and the black case. But you're going to take the spring and place it between the regulator fitting and the solenoid. This will lock the fitting into the "slow speed" mode, so you always have full time power steering whether your speedo works or not!
Now screw it all back together, re-install it and have fun!
