g50 shakes when idling
velvet hammer
Car: 1990 jdm Q45a 60000miles on the clock
After recently getting my Q back from the chain guide replacement job it shakes when idling. Idle is solid 900rpm but the whole car vibrates.Has new plugs , cleaned the afm and throttle body. Ohmed the injectors. Ive noticed u can smell petrol(gas) with bonnet(hood) opened. Also it seems worse when on an incline.Any thoughts?
Thankyou for your time
Who did the guide work?
velvet hammer
A workshop that specialises in japanese imports, theyve always been good with my Silvia for jobs i cant handle.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
New fuel hoses?
Idle should be around 650 at most. Something is very wrong.
velvet hammer
what else can i check?
Is it a rocking/shaking back and forth or is it a steady vibration like a misfire?
velvet hammer
its a steady vibration
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Do you think they might have let the timing on the one of the camshafts slip?
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
My Q shakes. Like it's really moving. It goes away onece I start driving, but idling or at a red light, it shakes like a demon.
My dad and I believe that a tune-up might help? Is that right?
As far as I know, everything is sound under the hood and the only problem i have is a bucking between 40-60 MPH.
Haitian_King wrote:My Q shakes. Like it's really moving. It goes away onece I start driving, but idling or at a red light, it shakes like a demon.
Read Wes's guide on how to check your injectors:http://www.q45.org/ohminjectors.html
sdkhalsa
Car: 94 Q45 06 M35
One simple item to check is ignition timing since the front area was disassembled. Of course, valve timing is an immediate item to look at. You might take a quick vacuum reading. A low steady vacuum is an indication of incorrect valve timing.
