Don't have camera,nothing lazy about it.There are 2 coolant sensors,one deep under plennum one on top of thermostat housing.The one near housing has a sensor half inch close next to it.One wire going into it,one wire going into injector harness at injector#4.It's half the size of coolant sensor. Would like to replace as the whole top connector spins yet it's still attached.Infinitiguy19 wrote:Still to lazy to take a picture?
It looks like it would be in your pic,on the coolant fill neck.OwnerCS wrote:Here's a picture slide show of hoses, wiring, sensors, and other items usually hidden under the plenum at the following link. Just sit back and let it run through the slides and follow the wiring with the yellow plug. The other sensor may be the one you are referencing.
http://s286.photobucket.com/albums/ll11 ... =slideshow
And a picture..![]()
