G50 Q45 tires on clearance
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Running 15x fittipaldi rims and have had unbelievable luck with tires for the past two years. Scored 4 bridgstone insignias last fall for $125 mounted plus tow and disposal. Scored another 4 studded Bridgestone Exaltos for $150 from the same shop. First time running studded snows on the Q in 10 years of ownership... Impressed.... . Same shop left me a message today offering 15x Potenza RE-11A for $320 mounted.
Would just like to inform all you G50 owners the 15x tires are going for next to NOTHING. Call your local shops and I bet you can score a set for next to nothing
Q45Owner
Car: Infiniti Q45
BCC93QT wrote:Running 15x fittipaldi rims and have had unbelievable luck with tires for the past two years. Scored 4 bridgstone insignias last fall for $125 mounted plus tow and disposal. Scored another 4 studded Bridgestone Exaltos for $150 from the same shop. First time running studded snows on the Q in 10 years of ownership... Impressed.... . Same shop left me a message today offering 15x Potenza RE-11A for $320 mounted.
Those are good deals, especially for the usually pricey Potenzas. Are they on clearance? I've been looking on Tirerack for new tires for awhile now, cuz I'm gonna replace mine within the next couple months and I'm still deciding which ones to go for. I might see what kind of local deals I can get though.
qship96
Car: 1996 Infiniti Q45
Be sure to check the date codes on those tires,as the Re 11a has not been made in that size for quite awhile.If they are unloading really old stock,that is a concern.
