Applied force is 22 lbs for all your belts. It's at the bottom of the deflection table, easy to miss. That figure is pretty standard for all Nissan belts. When using the gauge, it always goes center span on the longest unsupported span. There are little arrows on the belt diagram to show the right spots.Gort400 wrote: ↑Tue Apr 19, 2022 12:36 pmQ451990, I plan to buy the Krickit gauge. Question? I looked in the 1995 FSM and it only shows Belt Deflection in mm. Do you know how that equate's to Lbs on the Krikit gauge?
https://drive.google.com/file/d/15Adrz2 ... sp=sharing
Ugg, that's frustrating. It looks like I may have not done this job on the Q since I got the gauge. The FSM for my truck shows specs for both Deflection and Tension. The Q only shows Tension. I'll do some more looking later tonight to see if there's a conversion.Gort400 wrote: ↑Tue Apr 19, 2022 12:36 pmQ451990, I plan to buy the Krickit gauge. Question? I looked in the 1995 FSM and it only shows Belt Deflection in mm. Do you know how that equate's to Lbs on the Krikit gauge?
The way I read MA-10 is.... you apply 20 lbs of force down on the belt for a deflection of 7.5-8.5mm for a new alternator belt. just my thoughts.VStar650CL wrote: ↑Tue Apr 19, 2022 5:09 pmNo, it's in the '95 FSM on MA-10. Look at the very bottom of the tension table:
https://www.nicoclub.com/service-manual ... 5%2Fma.pdf
Correct, 22 but 20 will be close enough. The checkpoint will be center on the belt between the crank and alternator pulleys, there's a little arrow for "check point" in the diagram above the chart. You run it a bit and then re-check, it should be 9~10 after it seats and gets comfy. If it doesn't seat then check for crap in the bottoms of the pulley grooves, that can happen if the old belt was hydroplaning (don't ask me why they call it that, they just do. I guess beltoplaning would be awkward).
The info is all there. This is from the '05 Q45 FSM. It's 22 lbs (10 Kg) on the Krickit for all 3 belts. The 10 Kg is pretty standard for just about everything Nissan:
The Krikit gauge starts at 100lbs.....now im confused??????VStar650CL wrote: ↑Wed Apr 20, 2022 4:23 amThe info is all there. This is from the '05 Q45 FSM. It's 22 lbs (10 Kg) on the Krickit for all 3 belts. The 10 Kg is pretty standard for just about everything Nissan:
No, you're confusing yourself. Both specs must be used, not one or the other. Deflection is useless without knowing how much force to apply, knowing the force is useless without measuring how much the belt deflects. Belt tension is how much the belt deflects with the specified force applied.
By all means, you know more about this than I ever will. I think I'm not doing a good job explaining myself. I completely understand that you need to know the force you're applying to the belt to measure deflection - 22lbs. That 22lb force doesn't appear to apply when you're measuring tension. I believe the Krikit device works like a clicker torque wrench, so when it "pops" you've used the correct amount of force for it to measure tension in lb or kg. What's missing from the Q45 chart, that Nissan provided on other cars, is the area I circled in red.VStar650CL wrote: ↑Wed Apr 20, 2022 10:48 amNo, you're confusing yourself. Both specs must be used, not one or the other. Deflection is useless without knowing how much force to apply, knowing the force is useless without measuring how much the belt deflects. Belt tension is how much the belt deflects with the specified force applied.
+1. The serp on the wife's Altie made 110K before it showed any cracks. That's the main thing, replace at the first sign of cracking. Even small cracks mean the rubber is deteriorating. That exposes the cording, which will rapidly weaken in turn until the belt fails.
