Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jul 08, 2008 11:34 am
A 1 mm thinner front sway bar has the same ratio changing effect as making a 20mm rear bar a 20.5mm rear bar. As far as the change in roll stiffness ratio is concerned.
13% softer front or 13% stiffer rear. Remember the front bar [and rear] are /act in parallel with springs so 13% softer front bar is ~~ 6.5% less stiff front in totality since springs don't change.
Remember the front bar is ~~ 180 lb/in [or 156 lb/in = 28mm] while rear 20mm is only 40 lb/in WHEN the bushings are final compressed after 1" of body roll. Hopefully you can see that the front bar then becomes ~4 times stiffer than the rear creating the understeer after 1".
Just adding a rear 20mm bar makes the rear eventually [after 1"] 32% stiffer but when the front bar starts working [after 1"] the front becomes 100% stiffer still have significant understeer just less.
To make the car 100% neutral [a dangerous situation if you accelerate in damp road conditions] after 1" body roll you would need a rear bar as stiff as the rear springs 123 lb/in or a combination of stiffer rear springs and bar ...................somewhere around 260-270 lb/in.
Eibach rear springs are progressive and can achieve 200 lb/in after a 2" roll so with a 20mm rear bar you can get might close 200+40 = 240 lb/in.But the Eibach stiffness from 1>2" is not 200 maybe 160.
Progressive rear springs can be very squirrely abd suddenly surprising in that you go from neutral to understeer to near neutral under extreme handling.
My old Q has had Eibach's and 28/20 mm sway bars for 14 years but I am use to the weirdness and think about it in advance every time it rains or I get frisky and back off a little in curves.
A stiffer than 20mm rear bar will/could/can reduce body roll so that the Eibach's never get compressed 3", so the 200 spring stiffness rate never occurs. Why Stillen made and sold a 24mm [120 lb/in] rear bar with urethane bushings and stronger end links for use with Eibach's springs.
Not for use with oem rear sized tires they sold an entire package with 255/50/16 or 255/45/17.
The above are math number [pretty accurate] but you must use scales and jacks to get the 100% real as installed roll stiffness in each increment of inches to see what bushings, and tires subtract from theory.
This is why race cars have adjustable from cockpit while driving methods to change the stiffness of rear sway bars as the tires change and the fuel is used dropping upto 125 pounds of rear weight.
