texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Wed Jan 11, 2006 5:57 pm
Curious why the thoughts of changing from what is arguably the most sophisticated suspension system on the road?
I Finally experienced an active system related failure--the active side of the pump on my wife's car ('92, 150K) started leaking into the PS side--slowly overfilling the PS reservoir! Gotta do a reseal job on it now.
She was 350 miles away over in Louisiana when she noticed 'the puddle' under the car. A 'tune-up' place said )got a coolant leak, and oil leak, and ? Never checked coolant level before making the 'coolant leak', mistaking the yellow-green active fluid color for antifreeze. I talked with the 'technician' on th ephone and walked him through a correct inspection/diagnosis long distance. Kinda hard to swallow he couldn't tell the difference between green oil and antifreeze solution--much less did not even check the coolant reservoir or remove radiator cap to look-see. I have to admit the 'diagnosis' of the leaking from active to PS side and overflowing PS reservoir was a 3AM eureka! moment in my sleep.
The 'brown oil' leak was from a leaking oil pressure switch (leaked 3 qts of oil in those 350 miles! wasn't leaking when she left home. Repairs cost $62.50--$19 for switch, $36 installation, 3 qts of oil, tax.
