G50: Plenum Hose Diagrams.
Articles, troubleshooting, DIY's and how-to's for all Infiniti vehicles.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
How to use this information- There are 2 kinds of numbers in this article, they will be referred to as PART CODES and PART NUMBERS.
Part codes are the the 5 digit numbers plus letters. Example: 14056NA
Part numbers are the 10 digit numbers, they are the numbers that will actually appear on the part you are dealing with. Example: 14056-60U09.
The first diagram cross references all of the hose part codes, which are found on the actual parts diagrams to their respective part numbers. The way this works is you will find the part code on the diagram of the hose you want to replace, then reference its part number. Find the part number, and retrieve that part and put it on the motor. Its as easy as that!!
Return to “Infiniti Articles”
