Really? I bought my last one at 90k, put another 30k on it in two years, and the most serious repair I had to do to it was burping the heater core and replacing the front rotors. It basically needed *nothing* during the time I had it and everything worked flawlessly. Did I just get exceptionally lucky?maxnix wrote: Any one you get now will require a few thousand to put right.
No, you just squeezed the last miles allowed with no maintenance.Nosser25rs wrote:Really? I bought my last one at 90k, put another 30k on it in two years, and the most serious repair I had to do to it was burping the heater core and replacing the front rotors. It basically needed *nothing* during the time I had it and everything worked flawlessly. Did I just get exceptionally lucky?
actually 90-93 and 94-95 with the same ECU are gonna be pretty close, only difference is about a 100lbs heavier the 94/95 is (assuming no HICAS/ACTIVE)Jesda wrote:If you want to tighten up the 94-95, a few suspension mods and tire upgrades will do the trick. Acceleration improvements from the R.B. NICO ECU would bring it a bit closer to a stock '90-93, but I dont know how close. Consider also that any 90-93 you compare to is probably a bit worn out.
Welcome back to NICO.
Believe it or not, there was one hideous Q on ebay someone posted once, that was a 90-93 with the 94 fender/hood/bumper. Theoritically, that would give you both .qsiguy wrote:Don't forget that the 90-93 will probably need chain guides.
I'd go with the one you like the best. All things being pretty close to equal, it's down to cosmetics. I'm not a big fan of the "belt buckel". I like my '94
