G50 : Performance Transmission Questions
Clyons0203
Car: SLK55, Talon TSi, G35, Q45
Besides IPT who sells Billet Torque Converters??
I understand that the IPT Modified Selenoid Assembly makes the transmission shift firmer, but what does the upgraded valve body do??
I did a search and read this about torque convertersNow, the key thing to remember is that this will improve you acceleration but for every day driving, it generally makes your driving experience a real drag…. Almost literally because most cars have stall speeds in the 2000rpm range and driving a car where the engine is revving and revving and you aren’t really going anywhere until almost 4000 rpm gets a little old turn after turn light after light. Usually staying with the stock setting or a compromise between stock and the ideal performance-stall speed is in order if the car is going to be your daily driver.
Can somebody explain that further. I want a firmer shifting transmission, but not kneck snapping. Something i can take to the track but yet still cruise around with.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
IPT and Level 10 both get their billet torque converters from Dragon, http://www.converter.com ... Look for posts by jamesmost, hes got one in his Q, hed tell you how he likes it.
I have a high stall in my car, and i love it.. I think its about a 2800-3000 stall, james is a little higher than mine if memory serves... It makes driving the car a lot easier, at low RPMs its much nicer... I think a 3000-3200 would be about ideal, still very stockish with more power..
Let me put it to you this way, both my parents and grandparents have driven my car and have never noticed anything about it.... At least about the transmission, the suspension is another story
Generally you do the valve body upgrade to get the firmer shifts, and replace the solenoids while your in there.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I found this while searching on google...http://www.automatictransmissi...19197
What do you think?Good idea?(I ask because it's local to me, so would be cheaper for me to get hold of.)
I have emailed the site's pro on transmissions, to see if it will fit the Q45, and expect an answer in a week or two...
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
oz man-good find. the pictures are of our valve body. you can check your firewall plate- the USDM G50s have the re4r03a trans--not sure about jdm.only reason i even question this is that the webpage lists the 'nissan infiniti' under the re4r01a.i did a home brew valve body upgrade on mine, including solenoids for about $225 US, and a lot of labor. that included a new separator plate which i modified to increase pressure on the high clutch and intermediate band release (essentially to perkup the 2--3 shift). i know some on the board will cry heresy--but i went in with eyes open on a specific mission to make my 2--3 sharp until the trans dies completely.point being--decide in advance what you are aiming for. no valve body upgrade will replace burned clutches. you can also do cheaper shift firming tricks (on all shifts) by replacing/adjusting the line pressure solenoid and not tweaking the valve body metering at all.
Ozzie
'06 MK5 Golf tdi
Definitely have the RE4R03A trans...I guess I will have to get my torque converter upgraded too.Will I need a totally new torque converter, or can the trans shop build the standard one up to a higher spec?
elwesso
2007 BMW M Coupe
depends if you want rebuilt or billet. I generally say, youll spend $500 or so on a rebuilt TC, and I think the extra money is worth it for the billet.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
popop has some rebuilts pretty cheap. i have a billet convertor trims off swome weight and has a design that does not have any loss on the upper end. i dig it.
Ozzie
'06 MK5 Golf tdi
poppop refuses to ship to me, so I can't go that route.Where would I find a billet one?
elwesso
2007 BMW M Coupe
anyone who does Z stuff can do Q stuff.....
Ozzie
'06 MK5 Golf tdi
Nice, I have the only specialist Z shop in SA 5 mins down the road from me
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
Andy I would ship it to U but it will cost over $300 to ship to Hackham! Just hit me up and let me know!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:anyone who does Z stuff can do Q stuff.....
Not necessarily, especially if they don't have the G50 specific cards for the Consutl I.
But better than Jimmy Joe down at the corner gas station.
elwesso
2007 BMW M Coupe
my implications were that if theyre skilled in rebuilding Z AT's, they can do the Q AT (since theyre both RE4R0xA)
Ozzie
'06 MK5 Golf tdi
maxnix wrote:Not necessarily, especially if they don't have the G50 specific cards for the Consutl I.
I have that covered too!
My friend, the nissan mechanic who you heard on one of my old Q videos (He owns an R32 skyline), has access to the consult and the card to check the G50, including the active suspension module!(The nissan dealer he works at is 5 mins in the opposite direction of the Z shop!)
Ozzie
'06 MK5 Golf tdi
PopPop wrote: Andy I would ship it to U but it will cost over $300 to ship to Hackham! Just hit me up and let me know!
But what about the caliper bolts? j/k!
maxwell867
Car: 1996 q45
Is there any difference in the quality of work between IPT and Level 10. IPT wants approx $1450 while level 10 wants $1800 to upgrade torque converter and valve body. Both said they would keep car 2 to 3 days.
elwesso
2007 BMW M Coupe
IPT from what I hear does superior work....
However, you dont need to get a billet converter from them... you can get the billets from http://www.converter.com... dragon TC's.
maxwell867
Car: 1996 q45
How difficult a job is it to drop the transmission on the q45. Thinking of droppiing the transmission and getting a dragon converter then taking the transmission and having the valve body redone. Then reinstalling the transmission myself.
elwesso
2007 BMW M Coupe
its not terrible as far as transmission removals go... It will be fun to fight the exhaust down and the top bolts are fun to get out too....
