G50 performance radiator options?
subtle_driver
Car: 1989 240sx hatchback, 1990 Q45 5-speed, 1973 Datsun 240z, 1987 Starion Turbo, 2003 Subaru wrx, 1995 Infiniti q45 5-speed,
I'm on the market for a higher volume/cooling capacity radiator. What options are there? I looked for hours but came up with nothing. I'm assuming I have to build one myself or have one made.
Are there any cars that have more aftermarket options that are close to the same size that can be adapted to fit on the 1990 Q45?
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Look at the CSF radiator I got.. Its a little more capacity, but its all metal which certainly would help a lot... Its a drop in replacement and isnt too expensive, with a lifetime warranty... :)
subtle_driver
Thanks for the tip, I'm leaning towards a radiator that can handle say a turbo system, or at least gymkhana runs and my daily drive to work on the mountain roads with a/c on and going up hill in 105 degree temps. I have a new stock aluminum radiator, but i need more capacity...
qship96
Car: 1996 Infiniti Q45
Why not just plumb in a 2-3 gallon inline holding tank to increase total system volume- maybe place it in the space used for the cooler in the active suspension model- this would basically DOUBLE total coolant capacity, and could be plumbed with a bypass for winter if appropriate!
subtle_driver
I would rather have a bigger radiator so It will increase capacity and cool at the same time.
I don't need to take up room with a holding tank because I'm planning a turbo in the future.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
q45tech has a bigger radiator (custom Griffin radiator).
Here are some threads that might interest you:
Need a new radiator!
post5649965.html
Flushed cooling System Today
post4979375.html
RADIATOR EMERGENCY
post5426712.html
subtle_driver
Thanks for those links.
I'm still having trouble finding the old threads with the search option.
I see some threads about the brass radiator, but not the custom Griffin. I am interested in that one!
BTW, has anyone tried this in a 45 yet?
http://www.summitracing.com/parts/GRI-1 ... ion|Manual
lino
subtle_driver wrote:Thanks for those links.
Do you mind posting the links to the threads about the brass radiators so that all the good radiator threads will be here in this one.
elwesso
2007 BMW M Coupe
You should also look up what sijoko did on his Q, he custom fit a dual pass radiator from summit racing, might be more like what you want.
lino
elwesso wrote:You should also look up what sijoko did on his Q, he custom fit a dual pass radiator from summit racing, might be more like what you want.
"The radiator is an all-aluminum 24 x 19 double-pass unit with the inlet and outlet on the right side. It is a 2-core design and has more coolant capacity than the OEM even though it is not as wide. I used flexible stainless radiator hose to connect everything. It is similar to the Cool-Flex hoses that are sold by Summit and Jegs."
The above info is from:
http://www.nicoclub.com/archives/ride-o ... sts-5.html
elwesso
2007 BMW M Coupe
MASTER OF THE SEARCH!!!
Maybe you forget going to the US and just charge people $0.50 USD to do searches on NICO and other forums.
lino
A new member here johnwhitmire64 also has an upgraded Radiator on his beautiful Q.
Here are the specs he posted about his Q in the "OFFICIAL G50 (90-96 Q45) OWNERS CHECK IN!"
johnwhitmire64 wrote:My Baby; 1995 Infiniti Q45t (230k)
• New Engine Installed (162400)
• Full Engine Harness
• Garrett GT-4094 Turbo (Rear Mount)
• Intercooler
• Tial Wastegate and BOV
• Level 10, Stage 3 transmission
• ’93 ECU w/ NICO Tune (Thanks QSIGUY)
• New Bosch MAF
• New Instrument Cluster (105 Miles)
• New Radiator; Dual Core
• Electric Radiator Cooling Fan
• Oil Filter Relocated
• Oil Cooler/Pump in Trunk
• Relocated Battery-Trunk
• Gutted Pre-Cats
• Deleted Secondary Cats
• K&N Air Filter
• Foose Rims; 18’s w/ 245/40’s
• Tokico Blues
• California Custom Springs
• Jeff Williams FSTB
• SPL Rear Uppers
Other Replaced Parts:
• AC Compressor/Alternator/Water Pump
• Power Steering Pump/Steering Rack
Parts Waiting for Install:
• TCS Switch (Use to Change Tune)
• Auto Meter Gauges AM-3376, 3327, 3391
• Duraflex Full Body Kit
Parts Still Wanting to Buy:
• Z32 F/R Brakes/Rotors
• transmission Cooler
• 4.08 Rear End Gears
• Methanol Injection
• INTERIOR/Paint
http://s1226.photobucket.com/albums/ee4 ... 0%20Turbo/
subtle_driver
thanks for the info, I'll try and get more info on the aluminum double pass radiator. I had one made for my 240z that supports 800+hp, If I could buy one somewhere it would be nice. Or at least something I can buy and make own mounting brackets.
I'm not interested in the brass radiator.
