G50 Oxygen Sensors
cientortas
Car: 1994 Q45 Blk/Blk
Sparkplugs.com has three different brands for G50 oxygen sensors. All of them say OE Identical. They have Bosch, NGK, and Denso. The NGK and Bosch have different part numbers for the left and right O2 sensor. I'm leaning towards the NGKs. Anyone know which brand is better? Thanks.
sultan
i did the ngk's when i had a q, two of the 24154 ones. only difference is the length of the wire and since the longer wire one is cheaper you should just get two of those. i figure the plugs are good so the o2 sensors must also be good.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
NGK (or NTK) are the OEM ones.. Thats what I got in my Q, and I would recommend that. The left and right o2 sensors are good, and just get whatever one are cheaper, but the harness on the driver/pass side is not much different, maybe a few inches at the most..
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Go with NTK. Your car will thank you.
