I run the SPL rear adjustable links on my Q Stealin is for the weak!!JohnPa wrote:I just had my alignment (90 Q45t) on a Hunter machine and the mechanic thought that the adjustable links from a 300ZX of the same vintage would work on my Q. I'm interested because he says that the rear tires will wear unevenly at the current static setting.
If it will work, I know that Stillen makes such an adjustable link, but does anyone else to your knowledge? As long as I'm at it, does anyone besides Stillen make an adjustable front link for the Q?
Many thanks..................John
Jeff, my front links and tension rods are new, but I didn't replace the ball joints or king pin assemblies. Still, the camber is off front and rear. Did you replace both the front and rear upper links with adjustables? Where did you get them?Jeff Williams wrote:John, it appears that any adjustable link for the 1990 to 1996 300ZX will work on our 1990-1996 Q45 as well.
I bought adjustable links, to make my care more positive, because the tires wear a little more on the inside. I am also puting on some California Custom springs, that will lower the car about an inch or so.
Worn tension rods and upper links are the culprits on the front. The kingpin and lower ball joint could be a problem, as well. Sagging springs can put the car too negative, as well.
I can't give you any help on the wear pattern because the rears only had about a 1,000 miles on them when I had the alignment re-checked because I didn't trust the local tire shop that performed the original alignment. The fronts had about 4,000 miles and were noticably worn on the inside!sdkhalsa wrote:JohnPa:What was the nature of the wear pattern on rear tires at the static setting? What was the setting?
Good to know about the springs. My car would look a lot better if it were lowered. But, help me out here, who/what is 'SPL'?elwesso wrote:Am i not around anymore???
ALL 300ZX multilink things work!!!!!! Tension rods, upper links (front and rear), and so forth... ALL FROM SPL!!!!!
The ride with the cali customs is great.... trust me!
Hey Jeff, where did you find the 'spacer kit'?Jeff Williams wrote:I wonder why Wes hasn't responded to this thread....
I I bought a spacer kit for about $50, that replaces all 8 bolts, and adds 2 bars on each side, to move the OEM upper link inner mount out to compensate for a 1" dropped spring. They were advertised to match the Eibach springs on the 300zx.
