Found something online. Sometimes the link doesn't work so I'll post what's there and provide the link below:
Infiniti Q45 MAF Sensor
The Infiniti Q45 MAF sensor, which apparently flows more air than any other stock MAF sensor has an clear inside diameter of 3.19 inches (80mm) and is voltage-out (not frequency).
In OEM wiring harnesses, the wires are usually:
* Signal - White, pin "B", * Ground - Black, pin "D", * 12V - Black/White, pin "E"
There is a full output curve for this (and other) Nissan MAF sensors in this spreadsheet
http://www.diyautotune.com/meg...s.xls
Source:
http://www.diyautotune.com/meg...p.htm
