Does your Q spin the tires, from a standstill, if you stomp the gas pedal all the way down? That's what the right feeling is........I drove my Q for years, with bad knock sensors, not knowing that "right feeling." First test drive after changing my bad KS, I was like, wow, THIS is what a 300hp V8 should feel like
Big, big difference in takeoff. Make sure you use oem Nissan sensors.
