I need them to be adjustable to correct bump steer. OEM replacements will not work for this. The car is about 5-6" lower than stock.OwnerCS wrote:How about just using some MOOG built for G50? I believe MOOG can be found for about $50 per -- range..
You can thread s14, z32, z33, etc inner tie rods into the stock Q45 rack, they are all the same. The only difference is the diameter and thread pitch. So it would be easy to buy Z32 inners and outters and it would all function properly on a Q.BCC93QT wrote:Adjustable aftermarkets can be had... out of japan of course. I see them pop up all the time but only NEW
