Dabizzo1 »
https://forums.nicoclub.com/dabizzo1-u52713.html
Mon Feb 19, 2007 12:43 pm
Hey Chuby, there will be a small coolant line that connects on the left side of the throttle body (assuming you are standing over the drivers front fender)and another small coolant line that connects the right side of the throttly body to the plenum itself (side facing you) in front of where the egr bolts up. Another coolant line under and in front of the egr bolt up area again on the plenum itself is the coolant stream outlet which terminates into the engine valley. This stream of coolant is supposed to locally bring down the temp on the throttle body and the egr passage. These lines are very easy to forget to reconnect.....I did exactly that when I did my plenum job. Hope this helps. Boris P.
