Teach45 wrote:1.) Can the pum be going and manifst this intermitantly. Should I lt the tank run low and see if it is worse.
2.) Can the pum go without the buzz?
1.) Not usually. There is just more drag and it turns slower while pulling more current in an attempt to maintain fuel pressure. Why Q45tech recommended measuring fuel pressure.
Knowledgeable owners never let the tank go below ¼ in normal operation since the return line and the gas in the tank serve to cool the pump and the fuel system.
2.) Rare, but it has happened.
Modified by maxnix at 8:09 AM 1/18/2007
