when i started it to day she turned over at a low rpm i think it was around 500 not to sure but, then when i put in reverse it stalled out and would not start back up . waited a little bit and then started back up and stalled it out .........after doing this four or five time it started...
i don't think it the maf or it connector
squeefoo wrote:Wiggle the MAF connector until it straightens out and see if that helps. and then clean the connector very carefully.
Wes is right. MAF probs won't let it go past 2K R's.
i have cleaned it before not to long ago and i looked at it today and also wiggle the connector no luck
when driving the car it shakes or jolts forwards like, one side was cranking or as if you turning a key in a 5 speed with it in gear but, then it fine...... only for one second then the car will go past 2,000rpm while driving but when in park & neutral under no load it will go over 2,000 it all the time . the idle changes it go's up and down around 200 rpm it back fires when this happened and it blow my exhaust when the problem started, this was at it worsethe problem progressed and was not this bad the idle just jumped a little bit about a 2 weeks ago
what could this be? a fuel problem? a spark problem? idk
