sdkhalsa »
https://forums.nicoclub.com/sdkhalsa-u28278.html
Mon May 08, 2006 6:19 am
I wrote last week about harsh shifting which I thought was due to a bad transmission temp. sensor.After getting out my VOM, I found this to be the case, with all sorts of changes in values at higher temperature. Rather than spending a lot of time and money to dig out the old sensor, I soldered an adjustable resistor(trim pot) in the wiring just below the TCU cutting the connections with the transmission sensor. Normally, the voltage at TCU Pin #33 runs from 1.5V to .5V(cold to hot). I set the value at .75V(about 850 ohms). This has totally taken care of the shifting problem while at the same time maintained good performance when the transmission is cold. One special note here: I live in Arizona, so the temperature in the morning is almost 80 deg. to begin with. If you lived in a colder climate, this solution might require a different approach. My thought is that in a different season or different climate you might want to adjust the resistor to a different value.
