The key will be if it fits in the cradle properly and you can match the flow rate. For $50 give it a try. If you're wrong you can recoup the money by not going out to dinner the next Friday night.omarblackg50 wrote:.....Now if a G.M.C v8 fuel pump fits in the cradle and flows the same as a oe pump for 1/3rd the price what could it hurt.......
Actually, there are 3 flow rates as set by the FPCU on signals from the ECU. So it must have the same values for which the FPCU is calibrated.goody90q45 wrote:
