(G50) Fuel Injector removal technique
Q451990
I found a link to this in our Z forum... Check out step 33 and picture 46. This looks like it should work nicely on the Q injectors too. I never have been able to remove these without trashing them...
http://twinturbo.net/ttnettech/plenum/plenum.aspx
Heath
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Nice writeup. Plenum doesn't seem to be quite the hassle as on the Q45. I wonder if these older Nissans have the same trouble with ethanol as we do?
I wonder if you could pressure test the fuel rails for leaks using the fuel pump pressure before you bolt the rails down into the intake manifolds?
Q451990
Q45denver wrote:I wonder if you could pressure test the fuel rails for leaks using the fuel pump pressure before you bolt the rails down into the intake manifolds?
I'm pretty sure it's been done. I don't see why it wouldn't work....
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thats what I always do before putting the fuel rail back in.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Removing the whole rail at once obviates many of the problems of individual injectors on the VH engine.
Q45denver
1990 Infiniti Q45
elwesso wrote:Thats what I always do before putting the fuel rail back in.
Makes sense, since this is a problem area but never mentioned in any DIY write-ups.
