texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Wed Jan 10, 2007 12:54 pm
Don't use WD-40 on any internal brake parts--ANY residue will destroy the seals. Use ONLY 'brake parts cleaner'. NEVER use petroleum based solvent inside or around the brake system.
Be sure and properly clean out and relubricate the caliper mounting bolt holes. They tend to 'dry-out' and will not let the caliper 'float' properly on brake application--causing 'warper rotor' feel.
