g50 fog lights
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
My fogs keep working when they want to.Checked to see if everything is in right,nice and snug.Driver side has some glass melting issue going on.Is there a fuse to check? How hard to remove whole unit?
qship96
Car: 1996 Infiniti Q45
glass melting? sounds like someone installed a grossly over wattage bulb in there! The factory fogs are pretty useless,not much more than cosmetic toys.....turn them off and forget about them.
goody90q45
Car: 1992 Infiniti Q45 (sold)
black g50 wrote:....... How hard to remove whole unit?
Pop off the trim piece next to the lens and you'll see one bolt that has to be removed to get the entire assembly out. Once the bolt is removed it pivots out on a 2nd bolt that you can't see. Don't get the bolt to be removed with the beam adjustment screw. They're right next to each other.
