lino wrote:Can someone please tell me which one of the harnesses has the MAF connector on it and which one has the TPS connector on it?
This is all the information I was able to gather so far:
24079+B ______ HARNESS - ASSY - EGI , SUB (RH IGN COIL)24079+A ______ HARNESS - ASSY - EGI , SUB (LH IGN COIL)24079 ________ HARNESS - ASSY - EGI , SUB (KNOCK SENSOR)24075N _______ HARNESS - ENGINE , SUB (INJECTOR)24077M _______HARNESS ASSY - ENGINE ROOM SUB (Battery - Positive cable)24077P _______ HARNESS ASSY - ENGINE ROOM SUB24012 ________ HARNESS ASSY - ENGINE ROOM
Through process of elimination I'm not sure that this screen has the ENGINE CONTROL HARNESS that you need. Are the blue names next to the P/N's your typing or FAST?
The FSM pages that are attached show 8 harnesses and sub-harnesses and your list above only has 6. The last one, HARNESS ASSY, ENGINE ROOM, only passes through the engine compartment and has no connections to the engine.
The harness you need is the main Engine Control Harness. What's listed above are engine control sub-harnesses (4) and engine room harnesses (3).
Look for Harness- Assembly- EGI.
