Of course the Consult does..............connector corrosion? at either end of harness.
An interesting test/modification is to vary ^ the viscosity of ATF by using Redline High Temp ATF in increments 10%..............drain 2.5 add 1-2 quart [HT-ATF] to refill.
http://www.racerpartswholesale.com/redtech4a.htm
Each quart substituted will increase viscosity 3.3% so even 3 would be only 10%
About 2000 I tried 100% HT-ATF until winter when I had to cut it 50/50 so even that was ok.
