G50 diet on Titanium springs
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
Now that Ti is coming down in price, I was curious what the automotive industry was doing with this material.
If you Google titanium springs, there are several companies that will fab Ti springs for you.
This might be the ultimate G50 suspension setup, don't you think?
I also found that Ti might be available with disk brake rotors.
Such a weight reduction would really wake the Q up.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
How much weight would you save by going with Titanium springs? Maybe, ten pounds per spring.
Might be worth it if it is cheap enough. I would want to know how long the springs will hold their shape before sagging.
Now, there is a performance potential in reducing weight from the rotors since it is rotating mass. But I wonder how braking performance is affected by the lighter metal.
A big brake kit with titanium rotors might be worth it.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
even the cali custom springs only weigh about 10lbs each..... i doubt theres much savings there...
goody90q45
Car: 1992 Infiniti Q45 (sold)
The density of Titanium is about 56% of the density of steel.
66mgb
Current word is that Ti memory would last twice as long as steel.
Ti response rate is much higher than steel, therefore keeping the tire planted on the ground better.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, it is not unsprung weight. If the response time is different, one would need specially valved shocks. Titanium suspension pieces would be interesting, but not going to happen for a G50.
Q45tech
Half of everything attached to wheel hub is unsprung.............assuming you have the lightest forged wheels obtainable and the lightest custom aluminum suspension pieces, guess springs might be worth the effort [but 2 lbs for what they might cost?].........might be in the Forumala 1 price bracket. Along with the $2,500 each carbon fiber rotors.
Q45tech
Half of everything attached to wheel hub is unsprung.............assuming you have the lightest forged wheels obtainable and the lightest custom aluminum suspension pieces, guess springs might be worth the effort [but 2-4 lbs for what they might cost?].........might be in the Forumala 1 price bracket. Along with the $2,500 each carbon fiber rotors.
http://www.mtracing.com/home_files/page0013.htm
