G50: CSF 2-row radiator
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
all metal, #2652. 2-row. listed 1&5/16 core depth.
anyone used it?-fitment?-fitment with trans cooler in-between? (mine is pretty tight now with factory radiator (0&15/16 core depth--and the condesor pipe that goes laterally across).-filler neck the same (can continue to use OEM 88 kPa cap?)-draincock the same?- use of OAT with the copper/brass?
qship96
Car: 1996 Infiniti Q45
I had a CSF rad. put in my 96Q April 2007, works and fits perfectly so far. Not sure about the draincock,as I had it installed, and T3 did the only drain/fill as they replaced pump/thermo 11/07. Factory radiator cap fit mine fine, but I am pretty sure I got the aluminum/plastic end tank version,not the all metal one.
Go to http://www.csfimports.com to search their catalog { 2 versions for the g50} and get their info on required coolant type,etc. I think I requested the model with the plastic tanks only because I felt more comfortable with the aluminum core as opposed to the all metal model with the brass/copper core{even though the all metal version is a thicker core and 2 row as compared to single row on the alum/plastic model}
Modified by qship96 at 4:43 PM 9/3/2008
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
OK, reaserched the cap, that appears to be same.
OAT vs. copper brass search reveals some concern with lead solder seams in all metal radiators, but no hard evidence that i found.H-OAT lead solder compatibility undetermined.
question for the day: i've replaced G50 heater hoses before and my recall (sketchy) is that the heater core is brass/copper. can someone confirm?
qship96
Jay, the CSF website I posted earlier has a section on which coolant to use with each different type radiator they sell,did you see it?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
I checked the catalog before, not tech section---but did now......
kinda the conclusion i was coming to: G-05 (HOAT) preferred for copper/brass.still--have had (orange) OAT in for over 3 years on factory heater core.
HOAT is also compat with the all-aluminum engine.
I bought the CSF with metal end tanks for my 92 Q. It performed flawlessly in midwest heat.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
thanks Jesda. remind me: did you have the transmission cooler in the 'gap' (rad to condensor).
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
i have a CFS for about 1 year now no issues
