3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Mon Feb 19, 2007 10:38 am
dug in to replace the 2 little bulbs in the message center and replace the roll pin in the left pivot of the ash tray. that all went beautifully.about the time i was unplugging the 4 harnesses from the speedo cluster, i noticed the map light that i had put on to help see went out.figured it would spontaneously come back at some point during reassembly, but no.as far as i can tell, EVERYTHING else works. Can't hail the lights with the dimmer switch, key fob,,,,lock/unlock works, seat positioner works, etc.
message center reads 'door open' when a door is open and 'ok/mileage when all doors closed.
.soooo, what might i have screwed up??
