G50 Coolant Temperature Sensor- Part Number request
goody90q45
Car: 1992 Infiniti Q45 (sold)
The temperature gauge in the 94Q instrument cluster quit working so I switched the coolant temperature sensor with the 90Q and the problem went away. I was surprised since I hadn't heard of this part failing but it was a lot easier to remove than changing the thermostat in 95 degree sun. I need to get a new sensor but would like to have the P/N in hand. Has anyone purchased this sensor? Know the cost?
It's formally called the Thermal Transmitter (94 FSM page EL-42) mounted on the fill cap inlet pipe near the block. The sensor is about 1/2 the size of a spark plug with a single wire connection that's part of the FI harness, not to be confused with the Engine Coolant Temperature Sensor (aka ECTS, 94 FSM page EF+EC-12) right next to it that has a multi-wire connection and goes to the ECU.
Thanks for the help.
Black stallion
Car: 1994 Infiniti Q45
2006 Infiniti QX56
22630-44B20 $29.17 @ Inf. of B.R.(for non-tcs)Hope this helps
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
I think the part you are asking for Mike is called the Temperature Sensor. If so, then here is the relevant info:
Part Number: 25080-89903 (same part number for all years)Prod.M/Y: 08/89 - 07/90 Prod.M/Y: 07/90 - Price $18.19
lino
Black stallion wrote:22630-44B20 $29.17 @ Inf. of B.R.(for non-tcs)Hope this helps
Part number 22630-44B20 sells for $21.88 at IOS.
Part number 22630-44B20 is the Engine Coolant Temperature Sensor which I believe is the one that Mike asked us not to get confused with.
If I'm mistaken, then here is the relevant information:
Engine Coolant Temperature Sensor:
22630-44B10Prod.M/Y: 07/95 -
--> part 22630-44B10 supersedes to 22630-44B20------------------------------------------------------------------------------------------
22630-71L00Specification:F/TCS Prod.M/Y: 07/95 -Prod.M/Y: 02/93 - 07/95
22630-71L00Prod.M/Y: 02/93 - 07/95
--> Part 22630-71L00 supersedes to 22630-44B20
22630-V5010Specification:F/TCS Prod.M/Y: 07/90 - 02/93
22630-V5010Prod.M/Y: 08/89 - 07/90 Prod.M/Y: 07/90 - 02/93
--> Part 22630-V5010 supersedes to 22630-51E00 which then supersedes to 22630-51E02
goody90q45
Thanks Marcus / Lino. Got the P/N of the one I don't want and the one I need. For a less than $20 part I think I'll take the short drive to the stealership today and test their Nissan FAST skills.
lino
Is this the part Mike?Sorry about the poor quality pics, I don't have a nice camera:
goody90q45
That's the one. Interchangeable between my 90 and 94 Q's. Thanks.
goody90q45
Done. Only $26 at the stealership (20% of their list price). Alphonzo the parts guy (he recognized me by name) sent me to the Nissan stealership to buy it and saved me a return trip since he didn't have it in stock.
The new one is lot prettier than the broken part.
lino
That was a quick fix Mike. Glad your friend at the parts counter didn't make you wait for a special order since that part fits so many cars:
Nissan Model Series:D21 , D21U , WD21 , Z31 , Z32 , B11 , B12 , B13 , GC22 , U131U , J30 , K10 , KN13 , M10 , M11 , S12 , S13 , T12 , U11 , U12
Infiniti Model Series:G50 , F31 , JPY32 , P10
