silkysmoothyjud »
https://forums.nicoclub.com/silkysmoothyjud-u50966.html
Sun Mar 18, 2007 7:07 pm
Ok bud, you just lucked out I think. Now that its getting warmer in Missouri Ive noticed that my car is a lot smoother. Therefore, Wes was right about it being rubber.....It's more than likely your tires. Either your getting crud stuck in em in the winter, or the rubber on your tires is hardening from cold weather. I've got seventeen inch wheels sitting on low profile tires. Ive noticed the noise from my tires have decreased in warmer weather as well (first winter with my new ride). I only paid 425 Dollars for my set of Hankook Ventus tires. I thought I really jacked up my alignment when I did my tie rod boots until it got warm outside. Do you have low profile tires on your Q? If you do, then I would say there's at least part your problem: 99.9% sure. When's the last time you've dropped your transmission pan and/or put in four fresh quarts?
Modified by silkysmoothyjud at 10:18 PM 3/18/2007
