superuber wrote:yeah we wanna see.Clyons0203 wrote:I can post some pics of mine if any one cares?
Jeff, as I recall the 300Z AT diff has a lower (higher numeric) diff, that's what makes it more desirable.Jeff Williams wrote:Can I assume that the 300zx NA diff doesn't have to be VLSD?
Is there a difference in the automatic diff and the manual diff?
Thats what I said in my first post. I have the pics I amloading them now.rsiwicki wrote:Non-Turbo Has 4.08Turbo Has 3.xx
You want a diff out of a non-turbo Z32
Rob - yours with the gear spacer is cleaner, but kudos to superuber for going where no Q has gone before.rsiwicki wrote:thanks for posting pics....I must give you credit that you are certainly the first we have heard of going this route. I had mine custom built and it still needed "longer" carrrier bolts as I ripped one right through the metal when it broke loose. They also used a spacer so mine was pretty much dead center on, but that is small in comparison to ripping a carrier bolt through the casing like it was butter.
Congrats on doing this mod both cheaply and sucessfully.
You're right, the abs sensor is on the front. You can't see it with the pics.Yes, it is much cleaner with the spacer. Who makes the spacer?As far as the boot being pushed in on the right side, it is 1/8 or maybe1/4 of an inch. It should not affect it at all. If a spacer could be had for this mod it would be alot easier!Yeah, having the shop to do it in is nice too! But if you had air tools it wouldn't be to bad. The diff is easy enough to get out.Good luck to all you who plan to do this!RobertsnewQ wrote:
Jay - the non TCS Qs have only 3-channel ABS so the pickup is on the input flange.
So the LSD ring and pinion gear is different than the non-LSD ring and pinion?elwesso wrote:you want the LSD
ur car does not have that problem or does not have TCS ??superuber wrote:I know james has had issues with his traction control. My car doesnot have that. The only issue I have had is a leaking seal. As faras driving my car like you, I assume you mean hard. At times I driveit very hard, also I am putting a 100 nos shot to it. If thats not hard on itI don't know what is!! I can get the Q on the lift today and snap some pics. My rear is not apartbut I do have the old z diff and another Q diff. I can show what I did.
http://community.webshots.com/user/neheadsuperuber
I think this mod will reduce times. The gear ratio change will cause the Q to accelerate alot faster, but will also make the car spin more off the line. Some nice wide tires\rim should handle that.rsiwicki wrote:Do a search on the 4.08 or contact Jamesmost (NICO member) and you will have plenty of knowledge to make an informed decision. Spend monies on other mods first unless you got monies to burn as it will not reduce your 1/4 ET's and also will make it more difficult to hook up from the stop light.
So, It sounds like a tcs car will probably have issues with this diff ratio that need to be sorted?? ANyoneknow how to trick the tcs into seeing the wheel speeds that it wants to see?jamesmost wrote:did not swap back, still having issues w/ tcs/slip/abs have not had time to play around w/ it
