G37x service cost
vbossio
Car: 2009 Infiniti G37x
Hello -
I was recently quoted these prices by my dealer for service:
transmission fluid change: $300
AFI (Fuel Injector cleaning): $300
AWD fluid: $300
Are these prices reasonable?
Is it safe to have a different auto shop handle these (assuming they are cheaper) ?
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
How many miles do you have on it??
prices sound high
Check prices at Nissan...check your local Nissan dealers website for coupons too.
They also have a rewards program where you get back money that can be used on parts/services.
vbossio
about 65,000 miles
I'm getting much cheaper prices from another auto shop near my dealer
audtatious
Skip the AFI cleaning and run a can of BG44k through the system.
justinbellaa03
Car: swift
i have visited this G37 forum.it is very beneficial for me.The G37 Coupe's refined platform and chassis includes an available advanced 4-Wheel Active Steer (4WAS) system, while braking and handling is targeted to be among the best in the luxury sport coupe class. The discs are 13 inches in diameter all-around.
The G37 Coupe is offered in a range of four models: G37 Coupe, G37 Coupe Journey, G37x Coupe AWD, G37 Coupe Sport 6MT and each equipped with a standard 3.7-liter VQ-series V6 with VVEL (for Variable Valve Event and Lift) rated at 330 horsepower and 270 lb-ft of torque.
2013 MERCEDES BENZ SL-CLASS
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
do the AWD fluid your self and run the BG44k your self.
for the awd just buy a bottle of matic S... about $16 a dealer, if you have ever changed your oil you can do the awd fliud. its literally unscrewing two bolts, a drain bolt and a fill bolt. only special thing you need is a pump simular to a soap dispenser to pump the fluid back in the awd transfer case. took me less than 30 mins to do this going slow. it is not worth $300. id say you pay any mechanic $50 labor to do this at most.
