I have bought a new, used car for myself. 2011 G37X, There is tons of sludge in it and it is not starting now. (Bought not running.) I got a motor from a 2wd and found out the driveshaft goes through the motor. I can return it and get a higher mileage motor that looks worse but before I do this is my question..
Can I simply change the pan spacer from the standard 3.7 to mine the AWD and the oil pick up tube or will there be much more than expected?
Example.. Harness, missing holes for Alt mounts and motor mounts ext...
