G37x Ignition/security issues on start up
mtc7121988
Car: Infiniti 2011 G37X
Hi guys I'm having problems with my 2011 G37x that I really need to get fixed so I can get to work in the morning.
I think the car may be in immobilizer mode unfortunately but the strange thing is that I can get the car to turn over if I time it right but the car won't physically run. Also after trying to start the car the push button start will be stuck in the "on" position and even when pressed to put the car in the "lock" or "acc" mode it will still stay in the "on" position until the battery of the car dies. Also the front marker lights and the rear running lights will stay on even though the light switch on the steering column is in the "off" position. I have checked all the simple stuff and have made sure the battery is good. I had the battery hooked up to a trickle charger for a good 6 hours and took a meter reading @ 12.6VDC. Additionally, I tested all of the fuses in the fuse box by the drivers feet and the fuse box next to the battery in which you need to remove the plastic battery covers and plastic covers at the bottom of the windshield. On the dash the yellow key indicator light is on and when I can get the car to turn over there is also a solid red security light indicator. Checked to make sure all of the fluid levels are good to rule out some sort of engine safety interlock.
About a month ago a similar issue happened to me. I drove the car in the morning and there was no issues but it was also a rainy day. Parked the car and when I went to drive it later in the day the car would again turn over put wouldn't start immediately. After about three attempts at starting the car I was finally able to get it to start so I could move it so my girlfriend could get her car out. After moving the vehicle and turning it off I tried to get it to start again but this time the steering column lock actuator was stuck and wouldn't release. Long story short I was able to get the car to start after tracing out the ignition systems wiring diagram. Basically there is a pink wire on the harness that goes into the steering column lock actuator that when it has 12V running through it, it will not allow the car to turn over and disables the ignition system. I tapped this wire to test to see if it did have 12v running through it and sure enough it did. At this point I cut the wire brought it to ground and re-fed the other side with this 0v grounded signal. The car started right up and some how the steering column lock released. I returned the wiring to how it was before and haven't had an issue until now. Obviously, when this similar problem occurred yesterday (also when it was rainy) this connection was one of the first things I checked. The connection seemed fine but I re made the connection with some butt splice connectors just to be sure it was good. Im not really sure what to do at this point but any suggestions or help would be greatly appreciated. Thanks so much in advance guys.
mtc7121988
Also I forgot to mention that I blew the engine in this car about 20K miles ago and the transmission about 30K miles ago. Both were replaced by the dealer and a whole new engine wiring harness was put in the car. All of this work was done before the two issues mentioned about. Im not sure if any of this work is related but I figured I would mention it. Thanks again
