G37x coupe - lowering, has anyone done it and how?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
shnur
Car: New :) 12 EX35
Gone :( 09 G37x coupe
Hi
I just picked up an 09 G37x coupe and wanted to see if anyone has lowered it and how they've done it?
I'm thinking of getting the G37 S coupe springs which I guess would be a little shorter and maybe won't void the warranty, any ideas?
Or alternatively, getting some H&R Sport springs? Again not sure if these will lower it too much (over 10%) affecting the struts.
thanks for any ideas and comments and info
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
The quickest way to lower your car is to fill it with concrete, but that kinda ruins it forever. The springs for the G37 RWD are about $100 each, and I'm not sure if they're a direct swap. I would imagine so, since the 1st gen sedans and coupes are swappable.
EKUHN
Car: 2007 G35X
I've used the Eibach ProKit springs for my 07' G35 sedan. Lowers the ride by 1". Does require getting both front (~$350) and rear (~$125) alignment kits installed to allow correct camber/caster/toe to be set. You really want to do all the kits at one time otherwise you'll waste a lot of money on labor.Great overall feel to the ride with vastly improved cornering. Stock dampers are ok, but down the road should upgrade to Koni yellows or D-spec's.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
