G37s steering
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Henry1003
Car: 2008 infiniti g37s
I have a problem with my 2008 coupe g37s. can any one help me.When making a tight turn left or right the wheel does not come back to center. the infiniti dealer is telling me that this is normal for the sport model! I find that very odd.
audtatious
So, your steering wheel is not centered or does not straighten out completely after a sharp turn without you manually centering it? If that's the case then I've not experienced that issue that I'm aware of.
Henry1003
Yes, the steering does not center after a sharp slow turn, such as turning in a parking spot or turning in a circle in a lot....Thanks for the reply.
I have an appmt at another Dealer Thursday. I'll see what they say.
audtatious
Tires themselves should straighten the wheel as they try and track straight. If you are going very slow then It's possible it won't. What speed are we talking here?
Henry1003
not very fast; 5 to 20mph about the speed you take asharp corner.I have a coworker and his cousin owns the same model year except his is manual. He has driven boyh cars and he states that his cousin's car does not have the dead spot in it.
audtatious
Dunno, I have surely not noticed a dead spot in either of mine.
Henry1003
Well, Thanks for the info...I droped the car off at another dealer last night. I'll see what they say!
audtatious
Did you get a loaner? does the loaner do it if it's another G?
Henry1003
I did not get a loaner because I have another car that I am using for the winter(I should have).I did talk to the service writer about the problem I was having, the way other G's drive and he said"He drive them all the time" and that he has never felt that problem.(at least this dealer cannot use that excuse).
audtatious
Sounds positive. Let us know the results.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
