Did you check your tire pressure?tep wrote:Hi all:
I need some help. First off, since the day I purchased this G37S coupe, I had issues with the Alignment it seems. The car is either very sensitive on the roads for all bumbs and etc.
I have to constantly steer it or correct the path if not it will just suddnely move to either left or right. I took it to the dealer they checked it and said nothing wrong, but they again did a four wheel alignment. But that did fix the issue 10%.
I am wondering any of you has a G37S coupe sports pack, feel the same way. I used to drive a G35, OMG that machine was on the road do not move anywhere even if the road is a crapy road. What's with the G37? Please let me know.
This only has 900km. I mean is this normal? Dealer says yes. I dont trust the dealer. Need some help from people who owns G37 Coupe.
Thank you for all your help and information.
I have the same issue with my '08 and it's caused by some inner cupping of the front tires. I've simply dealt with it and have 32k on mine at the moment.tep wrote:Did you mean like a Computer Generated print or just the work order with information? Becuase they said it was off a bit and they adjust the front and back tow in or someting like that.... i forgot the proper wording. It did fix the issue 10% but not all the time. The funny thing is that, steering can be 100% straight, but if the road is just little off eventhough the steering is straight, the car will pull to the side(left/right). That's the wierd thing. I am going to take it back to the dealer and tell them again.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
