Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Tue Aug 19, 2008 6:07 pm
This is unusual. I would dare say that there is a 50-50 chance that your rotors may be a result of factory defect. Has any G-37 owner experienced this problem yet? The dealership should have owned up and replaced all your rotors under warranty if this was the issue. Even my little nissan that was made many moons ago, does not have such an issue. Have you replaced the brake pads since it started this problem or are you just machining the rotors without changing brake pads? If you haven't changed brake pads, no matter how much machining you do, you will keep getting the same effecte, and there is a 50-50 chance this could also be the problem.
Another thing that could cause this effect you suggest could be rust on rotors. Sometimes, rust can cause the brake pads to wear prematurely and unevenly. I noticed it in my car when I bought it. I replaced the first brake pads, and machined the rotors. It felt like it griped a little better after this.
