G37s Question about rims..
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
hyekid10
Car: g35
Hi all,
I just went through some threads and didnt notice or see the place to get my answer, so i am going to ask it myself. I am not good with tire offset or the measurements so.. here i go..
I got a g37s, 19 rims front and back, 1. arent they all the same rim? or are the measurements a bit off?
2. What is the MAX size tire i can put on the rear, and the max to put on the front.
also, a better company then BRIDGESTONE or a better place to buy the damn tires cuz everywhere i go, there f'innnnnn $332, $330... around that price range.
Ive heard of toyo's being veryyyyy sticky tires and good grip..
Just need some precise info.
Thanks
audtatious
Fronts are 19x8.5 and rear are 19x9. 265 should fit relatively easy on the 9" width rims and I believe some have run 275's.
Not sure about tire replacements yet as I still have plenty of tread left on mine. I will probably upgrade to 265-35's on the rear.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
