Today i was using my power walk-in system on the driver side for the first time, and it worked fine.
But on the other side, the passenger side, it has a problem.
When i fold the seat forward and use the power slide button (see attachment), the seat goes forward as it should.
But then when the seat is in front and i fold the seat back again to the upright position, and i push the button, nothing happens???
It should go back i presume?
I read some parts in the FSM of the infiniti Coupe, and there is something about a initialization of the seat after
you disconnected the battery power. I know the previous owner has replaced the battery.
I tried to do this synchronization: Seat to the front, then to the back and again to the front.
Probably i am not doing this the way it should, because it doesn't work!?
Maybe somebody has other ideas about this problem?
Hopefully you guyscan help me out!
Thanks....
